L400 grease points for doors
joedelica
Vehicle: 95 Exceed XR The Sapporo Can
Post by joedelica »
Anyone have an idea of where the grease points would be for the doors?
Since the weather has been cold, my passenger door almost requires two hands to close it!
Joe
nxski
Re: L400 grease points for doors
Post by nxski »
Wherever it hinges from!? :-D
I use SAE 20 weight oil on all the hinge points on our L400. It's been good so far though the winter in Whistler cold. My sister is tiny at 5'1 and has no problems with the big doors sticking.
If you have old grease or gunk, use mineral spirits to clean off the stuff and then apply liberally a good weight oil or lubricating grease (marine blue stuff is good too).
Hit every hinge/pivot point.
joedelica
Post by joedelica »
Thanks Jesse!
And Nxski don't give up your day job!
Joe
nxski
Post by nxski »
joedelica wrote:Thanks Jesse!
Joe
:-D I'll bite, I use lithium ion lubricant on all sliders and hinges after cleaning them with simple green. And all while working 4 day jobs. 8-)
joedelica
Post by joedelica »
Thanks Nxski,
Do I have to remove the two screws on the inside door edge where the arm enters the door, or remove the entire door panel to grease?
Joe
nxski
Post by nxski »
If you have a 'creeping' lubricant you shouldn't have to remove anything. Unless you need to clean them!? Mine all worked perfectly after a simple lube. The passenger door hinge has dog hair in it so that will need to be taken apart at some point (what I mean by needing a clean).
