decrease in boost pressure
lost1
Post by lost1 »
I just noticed that my turbo boost pressure has dropped 5 psi at maximum load. Any suggestions why this happened?
mitch
Post by mitch »
You boosted your turbo right? not to be a downer, but you think you might have fried a seal or lost compression??? Only a guess hav'nt worked on mine yet
Mitch
lost1
Post by lost1 »
hope not, its pretty much a standard modification...
lost1
Post by lost1 »
I may be getting closer. I found a site on the internet that says if the Relief valve (blow off valve) isn't working right, that it can reduce the boost pressure. Don't really know how I can fix this, but I will have a look in the coming days...
VADLEM
Post by VADLEM »
could be the relief spring is going soft or a vacum leak in the actuator line
lost1
Post by lost1 »
Well after cleaning air filter and intake tract, wastegate, and Relief Valve in additiong to jiggling and playing (using a bicycle pump) with the vacuum actuator. I have yet to find the problem.
I will try and have a better look and see if I can find a vacuum leak on the actuator line.
thanks for the advice
David
Post by David »
How does one notice a drop in turbo boost pressure of 5% under max load?
1991 Delica Exceed
Chewy
Vehicle: 1995 Suzuki Every VW
Post by Chewy »
5psi ( lbs per sq. in.) :P with a boost gauge 8)
if there is a leak on the actuator line, you will increase boost. check all of your charge pipes if you already havent, if you know someone with a compressor and a regulator that makes it far easier.
as well, I'm not too sure about Deli's in this sense. but you may want to check that the bolts are tight holding the exhaust manifold to the head and as well the ones that hold the turbo to the manifold, they can back off and you don't even notice the sound change over the usual diesel valve clatter, either that, or the gasket between the mani and the turbo.
