mararmeisto wrote:NOW you're in the in-crowd. Nice looking rig. More pictures please. How much work does/did it require?
I wonder what it would take to drop a 4D56T into the engine bay...
Northwest Mitsubishi Diesel actually specializes in diesel conversions -
and I've interviewed the guy - but we're expecting a baby this fall and I've still got a race car collecting dust in the garage, so it's kind of hard to come up with the scratch for a swap right now. I would like to toss the Mikuni 2BBL in favor of an Ozzie Magna 2.6 MFI manifold and Megasquirt'n'Spark at a minimum; maybe throw one of these turbochargers on it.
Rather than repeat the whole story, I have a blog setup for my Mitsubishis -
Tarmac & Gravel - if you'd like to get the full rundown, but a high level overview of how much work it'st required...
1st weekend with it: Rear door wouldn't unlock from outside, lubed all lock cylinders. Problem solved.
2nd weekend with it: Removed non-functional alarm box, no longer starts with key, came with push button bypass. Problem "solved."
3rd weekend with it: Kid in Honda makes wild right turn from inside lane, US$1600 in damage, lies to insurance, I'm going to court soon.
4th weekend with it: Starts, dies, starter won't turn. Turns out you need 3FT of extensions to get the starter out. (Literally.)
5th weekend with it: Replace starter. Problem proves to be corroded starter lead from battery. Problem solved.
6th weekend with it: Battery dies. Replace battery. Problem solved.
7th weekend with it: Local Montero guy shows me the ropes, we do plugs, wires, cap, rotor, bleed brakes/clutch, grease front end, etc.
8th weekend with it: Drive 1,000 miles round trip to California rally race outside Death Valley. Not a single hiccup.
Will need front brakes this month. Will need tires by July. Oil leak will wait for the not-hot season to return. Should probably think about changing driveline fluids over to Redline synthetics here pretty quick, too.
Can't wait to go camping with it once we get back from "GBXM World Tour 2012" in June! :)
Some more pictures...
I still need to figure out what to call the damn thing, though. My 97 Talon was "Daisy" because she had personality. My 86 Volvo wagon was "The Brick" because it was the color, shape, and speed of a brick. The GVR4s were like cold, unemotional Borg, referred to by only their badge numbers - 195 and 464 - but this thing has personality like Daisy did. When I climb aboard, I feel like anything is possible.
To adventure! Huzzah!
But what do I call it? Monty seems hackneyed. I toyed with calling it the "Lost Ark," since it's a Dodge Raider (on paper, we know the truth), but something's missing from that. When I swapped out the Dodge grille for the Mitsu piece I flipped the V6 badge (since it's a 4-banger), which kinda looks like "9Alpha," but that seems too cold for it. I want to call it "Donkey," like Hammond did his Landy in the Top Gear Bolivia Special (which everyone here should watch if they've not already). But it could also be my "Toaster," since it's toaster shaped, has no AC, and pretty much bakes you alive down here in Phoenix.
Any ideas?
