New Member with start a starter that will not crank
- Vehicle: 94 SpaceGear 2.8L
Can anyone tell me off hand the starting system logic?
Re: New Member with start a starter that will not crank
The van is a 94 SpaceGear L400 2.8L
- tonydca
Insert key, twist, away you go...SirNewton wrote:Can anyone tell me off hand the starting system logic?
Seriously; are you getting voltage to the starter ("click" when you turn they key) or nothing at all?
As far as logic goes, you need to be in P or N, as per other auto trannies (assuming you have an auto).
