L400 alternators in Nanaimo
Anyone know of a good spot in Nanaimo to get my alternator rebuilt? Mine died last week
- Vehicle: delica L300
Re: L400 alternators in Nanaimo
Don't know anyone in nanaimo but these guys I have hear good things about
PC auto electric
2984 Boys rd Duncan
250-748-4113
PC auto electric
2984 Boys rd Duncan
250-748-4113
- ccautos
- Vehicle: 92 Delica SE
I have them on the shelf for $275 exchange. Don`t have to wait for it to be rebuilt. Comes with 12month/20,000km warranty.
Thanks Glenn, sounds good. I would like to be running sooner rather than later. I have been out of town since it died, so I haven't had a chance to pull it out. Is it relatively straight forward? I've changed the alternator on my L300 before, but I don't even know where it is on my L400.
EDIT: think I found my answer:
chris wrote:I replaced the alternator a year ago and I took out the air box and the hose to air box to get access and had no further problems. I think I put a pipe on the ratchet for more leverage.
Here is the order of operations:
Chris
- MardyDelica
i do have brand new L400 alternator wiht 1 yr warrantty
buzz me in if need one
cheers;
cheers;
Thanks Mardy. I'll probably pick up from CC Auto, seeing as they are on the Island. I'm still trying to make sure that I need it replaced. I was taking off the wiring bolt and it arced. I assume this is because I charged up the batteries and it is still connected. So I started it up to take a look. The voltage metre doesn't go above 12V even when I give it diesel and the battery and oil lights are on.
I guessing what I need to do is pull the fuse for the alternator, instead of disconnecting both batteries, but I had a hard time getting he fuse out. I'll go try again.
- MardyDelica
your welcome, its better and safe if you take out the terminal of your delica.
much better thsi way and safe;
Cheers;
mardy
Cheers;
mardy
- ccautos
The alternator fuse is bolted into the housing, don`t pull too hard it will pull apart !!! Just pull both negative terminals and you`ll be OK
The voltage gauge will read very low for approx three minutes after start up due to glow plugs drawing so much amperage. Let the van run for a few minutes and then do a voltage check. Also we have found issues with the dual battery vans when they have an aftermarket wiring harness installed into the ignition switch (for turbo timer etc) that creates a high resistance in the ignition circuit. This in turn has caused several charging issues.
