I searched the Delica.ca forums for the last few days, but haven't found an answer that describes the strange tire wear that our 1993 L300 is experiencing.
We got these BF Goodrich All Terrain's (235 75R15 LT) installed in late 2008 when we got the van...that was 70,000km ago.
Had the shocks replaced, alignment done and a bunch of other preventative maintenance done at the same time.
Tires were wearing decently up until a year or so ago. I can hear some occasional clunks from the front end when I drive over something like broken pavement...it's quiet the rest of the time. I haven't found the van to be pulling to one side or anything.
On the front driver's side, the tire is wearing on the outside only
On the front passenger side, the tire is wearing on the inside only
The wear doesn't appear to be from something as obvious as over-inflation or under-inflation.
Obviously I'll require new tires and an alignment. But, I'd like to get the underlying problem fixed so I don't have this kind of wear on the new tires.
Front driver's side tire wear
Front passenger side tire wear
Rear tire, for comparison. A little bit of wear consistant with being overinflated, but I think not too bad for 70,000km
Aaron
