shock absorbers-pro comp specifics
alpo
- Vehicle: mitsubishi delica
I'm going to change the shocks on my van. I'm going to go with pro comp 913515 on the fronts and 919520 on the rears. The thing is that every time I see a photo on the internet it shows round style connecters on the top and bottom. My 93 l300 has round on bottom and stem on top on the fronts and round on the top and stem on the bottom on the rears. Can anyone clarify if these parts numbers are correct with the proper connectors for my vehicle and a good place to source them locally or through the internet. Would apperciate any clarification on this matter............thanks.
VanVonVan
- Vehicle: 1994 L400 SWB
Re: shock absorbers-pro comp specifics
I have a L400, but I ran into the same problem when searching online. Most sites use a generic picture that has loop to loop connections. I looked on the UK deli forum found my part numbers and ordered them locally from an after market 4x4 shop. If I remember correctly it is the 5th digit of the part number that says what kind of shock it is. 1 being pin to loop, 0 being loop to loop.
Hope that helps a bit.
Russell
Russell
alpo
Thanks Russell. I had a feeling that most of the sites were using stock photos. Appreciate the help and I'm sure a little more delving will uncover the solution. Have a great weekend..........Dean.
