So I pulled over to see why my van wasn't going into fourth gear and found that I had coolant in my transmission fluid...awesome
I got it to a transmission shop and he plugged his computer into it...
He found that I need a transmission speed sensor and a throttle position sensor. He wants to fix these two things before he moves forward and addresses the problem of the new radiator
Does this sound like a good course of action??
Any help/info/guidance would be greatly appreciated
Has anyone else had a similar problem??
Coolant in Transmission Fluid
Smellica
- Vehicle: Mitsubishi Delica
- Big-Bird
- Vehicle: 96 PE8W Spacegear
Re: Coolant in Transmission Fluid
dude has an MUT II computer reader??? WTF? Thats rare....not impossible but rare as chicken lips!
The water pump and engine heat would create a higher pressure than the the tranny pump which would force coolant in the little tranny cooler tank. Its very small approx 6-10' long and maybe 1 - 1.25' diameter. Probably has a crack or pin holes on the metal. Coolant it the tranny fluid could compromise the grab/friction of the clutch packs that engage each gear. The filter could be plugged too. Water/glycol and oils just make a frothy mess and gum up everything..and a tranny has so many little springs and fluid passages the gummy junk could plug the works to a point where a rebuild is the only recourse.
Hopefully you caught it early and all you need is a filter clean/change and a tranny flush which I would recommend to ensure all the coolant is purged from the torque converter and the internals of the tranny.
You could bypass the coolant tank and plug it off with a closed loop. Then conncect the tranny lines into them selves with a coulper/barbed fitting. This would get you by until a new radiator is sent/installed.
I thought the L300's had an auxilary tranny cooler under one the front steps?
EricE
- Vehicle: 1995 l400 swb
Check your overdrive temp sensor first , you can short the wire to ground then see if it will shift to od , yes the speed sensor and tps are also involved , you can easily check the tps for adjustment vita a volt meter.
Diver
- Vehicle: L400
