Thermostat replacement
I am having some over heating problems on hills, the way its behaving and searching the forum lead me to believe its the Thermostat...any recomendations as to a reliable repair shop who can replace it for me in the Richmond, Lower mainland area......? and I bet this has been answered before, but i couldnt find it!
- delicat
Re: Thermostat replacement
MardyDelica who's on this forum is located in Richmond and could help you out for sure. He's known to do good work. There's also Maximum Overdrive at the North end of #3 Rd in front of Cdn Tire who sells/service Delicas. They have their web page and are also on this site. Hope this helps. If you have a hard time to locate/contact MardyDelica I might be able to find his ph.# for you.
Regards,
Regards,
Overheating while climbing hills is most likely a rad/plugged cooling system problem. Replace the t-stat by all means since it is cheap and easy and a good idea for such an old vehicle, but also remove the rad cap and look at the cooling tubes inside (not sure if you can on these or not, dont remember off hand) and see if they are plugged or not.
- Vehicle: Super exceed 91
The Best garage in Richmond is... Well the name escapes me but it is the garage that both Mardy and MOD takes their vans. Here is the phone number 604 246 0500. The y have their own machine shop and are super FRIENDLY and good rates as well.
as long as the coolant in the radiator is a bit low you can certainly see the tubes, mine were quite clogged and led to a cracked head after overheating... don't let it happen to you!
- MardyDelica
hi, you can give me a call, & will try to help you here in Rmd area,
there is so many factor regarding overheat, as green 1 & our fellow delica owner ,maybe a plug thermosthat .
will have to see no problem, sometime the thermosthat is seized it wont open or water pump impeller is gone. i see some delica impeller broken & overheat.
just the age & never been change thermosthat or anti- freeze since new. let me know.
cheers
cheers
