Cold Weather Start Modification
JMK
Vehicle: 92 Chamonix
Post by JMK »
I noticed in the ih8mud forum someone recommended the following procedure, which I wonder would it work for the Delica?
"Unplug the temperature sensor for the glow system. It's in the housing above the thermostat. The block heater warms the coolant and the temperature sensor 'tells' the glow system it's already warm, so no pre-start glow. Unplugging the sensor does the same thing as the "Wilson switch" idea, and gives one full control over the glow system with just the ignition key switch."
The forum thread is here:
http://forum.ih8mud.com/diesel-tech-24- ... rting.html
