dash bulbs
- Vehicle: 1992 delica GLX
dash bulbs
Does anyone know where to buy the bulbs for the transmission gear indicator? I've looked at CT and Lordco and neither one has the right size bulb.
- Artacoma
- Vehicle: 97 V6 LWB
Re: dash bulbs
I looked as well and gave up . Ended up shuffling around the ones there to get my D and N going ,I think I used the 1bulb and the seatbelt bulb.
good luck
good luck
Rik
97 Series 2 V6 LWB
97 Series 2 V6 LWB
- MardyDelica
Re: dash bulbs
HI, you can buy it at napa small bulb made by osram germany, ask for the smallest one.
this will fit all the dash light for delica.
cheers:
cheers:
Re: dash bulbs
I found the NAPA in Victora (behind the Red Lion) and sure enough, they've got the bulbs in stock! Now all I have to track down now are the micro bulbs found in the dash switches (hazards, rear wiper, rear fan ect.). Even the guy at the counter was stumped when I showed him that one!!
- PolyTek
- Vehicle: Delica P35W Exceed 5MT
Re: dash bulbs
I notice that my A/C switch does not light, as I think it is supposed to. Does it use the "micro" bulbs as well? Anyone ever replace it?
D
D
The world is my oyster; tasty, yet often full of sand.
Re: dash bulbs
I also posted this in the general discussion, here is the part number for the wee dash bulbs:
OSRAM
12V, 1,2W
2721 W2x4, 6d
I was thinking of going to Radio Shack and looking to see what they have for 12V mini bulbs, maybe I can find some thing that will fit for the switch lights
Quick update:
One of the other forum members had trouble getting these bulbs from their local NAPA, told that the part isn't in the system. After rooting through the wastebin, I located my receipt and found that the part number is listed as 2721. Just FYI. It may be worth looking into the possibility of replacing the bulbs with LED's.
OSRAM
12V, 1,2W
2721 W2x4, 6d
Quick update:
