So, the other day I noticed that when I had my right signal on, the day time running lights and the dash light would come dimmer each time the relay would click! After further investigation late this afternoon, I double checked all lights for a bad resistance, checked the flasher relay, then the signal stat.. Still nothing. Back to basic... J'me gratte la patate!!! where was the last time I fiddled with the lights/something..
Da daa!! Je me souviens... During the summer months I run a solar system witch is rooted around my rear right tail light... This was my last known location I fiddled with... Found a open wired that was rubbing on the frame... That's weird that the fuse never went... So I checked the fuse panel for proper fuse... Looks like whoever fiddled with it mounted a 25Amp fuse it there... Should be 15Amp!
Word of advice everyone... Double check your fuse box and make sure you have the proper fuse Amp in place!!!
Bonne soire a tous!
http://www.delica.ca/manuals/L-300%20Ma ... seBox2.jpg
Bazinnnga.... An unwanted resistance!!!
- ChuckBlack
- Vehicle: L300 Jasper
L300 Jasper,
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
Furi
- Vehicle: 1990 L300
Re: Bazinnnga.... An unwanted resistance!!!
Great suggestion; added to the list. So the lights getting dimmer when blinkers are on signify a short?
- ChuckBlack
The engine would get extra loaded aswell! As soon as the relay would activate all lights would have a signal light motion but dimming... In the end I had positive on body ground... Giving unwanted load on all that was running!
L300 Jasper,
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
