Cold weather not turning over
thetms26
Vehicle: Delica LP400
Post by thetms26 »
Hey everyone,
I just moved up to a small mountain town and as the temps are dropping. My L400 won't turn over unless I jump it with another car. All my electrical systems turn on just fine as well as the glow plug indicator comes on. Any thoughts as to what might be the problem?
ynwa
Vehicle: L300 Starwagon TD
Post by ynwa »
Hey! That's a bummer. A few things to consider.
> Does it click or just do nothing?
> Do you change the weight of the engine oil when the season changes?
> If it clicks, that means there's not enough juice making it to the starter, which requires the most juice of anything in the running of any vehicle
> Check the ground and really give it a good cleaning at the contacts. Same with the battery posts and positive contacts.
Consider a dual battery?
Cheers!
1991 L300 TD Low Roof
1992 L300 TD Low Roof
1992 L300 TD High Roof
thetms26
Post by thetms26 »
Thanks for the input. It definitely clicks when I turn the ignition. Were would I find the Ground contact on the Delica? Also I already have two batteries in the delly does that mean I have a dual battery set up?
Thanks for your help
