uh oh air duct
Adrock
uh oh air duct
Post by Adrock »
well. I just pulled the cover from behind the drivers seat off to take a look at how im going to go about changing my air filter. That is when I noticed this
One of the air ducts is missing. What part of the process happensbefore this duct? Is it urgent that I get a new duct right away? I probably will anyways, but just wondering, it seems strange that it is missing.
on second thought, maybe this is a sign that I am to install a snorkel haha.
Adrock
Post by Adrock »
on another note, air filter replacement is a breeze. 2 minutes at the most, except it took me 10 because one of the brackets on the bottom housing was not holding properly when clicked down so I had to bend it to the same shape as the other with some plyers.
next its oil and fuel filter... not so easy unfortunately.
mitch
Post by mitch »
Yeah that missing hose stumped me too as mine dosn't have one either.. spoke with a Fuso mechanic and he figured thats how its suppost to be! figured it pressurized the chamber you opened behind your drivers seat and pushed air into the airfilter..... he said this was a way not to have the intake suck up debris and clog the airfilter ..... then causing a stall.
Mitch
Anybody have a hose there??
username
Vehicle: 1991 super exceed
Post by username »
yeah, i noticed that on mine too. seems like it must be like that for a reason if they're all that way.
Breadman
Post by Breadman »
same as both of mine. comfort in numbers
paul
Mystery Machine
Post by Mystery Machine »
As already mentioned, that hose is supposed to be missing... :wink:
The pipe in the bottom of the picture is the cold air feed taken from the front of the motor. It runs along the inside of the drivers wheelarch and exits as shown in the picture.
The intake pipe in the top left is where this air is then picked up and fed through the filter and into the inlet manifold.
The reason for the gap is that is allows any heavier particles picked up through the air feed pipe to drop out before reaching the air filter. If you were to connect these two pipes, you would find your filter choked in no time at all!!
When I got my motor, the whole of this area was covered in sandy dust! I would hate to think what state the filter would have been in if it had been fed directly through the intake system! :shock:
A snorkel is one route to get around this, but be VERY careful how you direct the intake. One of the guys over here found that his got very quickly clogged with flies when it was facing forward (made the engine really struggle through lack of air!) and when he turned the snorkel head to face the other way, found he lost performance because he wasn't getting enough air flow! :?
I'm taking delivery of another L300 next weekend ( :D :D ) which I will be converting to a 'dedicated' off-roader! (stripped out, packed with kit, full breather and snorkel system etc...)
I'll post pics of my 'alternative' snorkel system when I get it done.....should be quite an interesting option to consider! 8)
Regards,
Bruce.
josh
Vehicle: L300 poptop gasser
Post by josh »
A snorkel is one route to get around this, but be VERY careful how you direct the intake. One of the guys over here found that his got very quickly clogged with flies when it was facing forward (made the engine really struggle through lack of air!) and when he turned the snorkel head to face the other way, found he lost performance because he wasn't getting enough air flow! Confused
Couldn't you face the snorkle forward, but cover the intake with a meshing? I would assume that it wouldn't restrict airflow all that much, but it would keep it clear of flies (if you wiped it down everytime you got in or out of the vehicle).
Josh
FredVenne
Vehicle: L300 Exceed Pop-Top, Pajero Exceed
Re: uh oh air duct
Post by FredVenne »
I found the same “missing hose” in mine while opening the panel underneath the driver seats and kinda panic a little bit. Now that I realize that it’s normal, I am still wandering, what if I put a piece of pantie hose and rubber band over the holes. I noticed at the base of the bottom hose, a lot of dirt, small rocks. Wander where this dirt goes... Anyone did this or something similar?
-The Mighty Yeti
thedjjack
Vehicle: 1989 L300 HITOP!!
Re: uh oh air duct
Post by thedjjack »
On my snorkel I am planning to run a Pre-Filter.
Basically an oiled foam filter in the head (ran this before on a Jeep).
Just wash the filter every few days (I was doing Forestry work at the time) and pop it back in. Worked great.
pascal
Member's Photo Album: http://www.delica.ca/Photos/displayimage.php?pid=1
Vehicle: Toyota Hilux Surf TD
Re:
Post by pascal »
Mystery Machine wrote:As already mentioned, that hose is supposed to be missing... :wink:
Regards,
Bruce.
snorkel ?? anyone knows where to get a snorkel for Delica 92 super exc..
no road does'nt mean no way
Re: uh oh air duct
Yes, I do know. Type "snorkel" into the search engine and you will find 27 pages of information regarding this subject. This ought to help you get up to speed on this matter as well as give you some ideas. Hope this helps... smiles.
thedjjack
Re: uh oh air duct
Post by thedjjack »
this is an old thread!!! That is a picture of my Delica when Adrock owned it!!!
Adrock you will be happy to know it has a snorkel now!!!
Function only in my world unless form helps function.
Jordan
Vehicle: 89 low roof L300
Re: uh oh air duct
Post by Jordan »
Great idea with the PVC cleanout on the bottom.
RichD
Re: uh oh air duct
Post by RichD »
Ghetto Snorkel RULES. :-D
Richard Dagenais
