injection problem
Kalto
Vehicle: Mitsubishi delica l300
injection problem
Post by Kalto »
hello guys, so heres my probleme, just for you now i just change all the fuel systeme and its been test twice (injector, fuel pump, fuel filter assembly and both of the fuel tank) So when i start the engine its take 2 or 3 shot of crank for starting and after it runs good on the idle but when i raise the rpm and release the fuel quick, the idle start to run low and stall after a second. could it be the advance timing cause i did it approximately, i dont have the special tool.
pluckmyeyeout
Vehicle: 1991 Delica Chamonix (JDM)
injection problem
Post by pluckmyeyeout »
This is the same problem I have! I was planning on just getting it rebuilt. But I'd love to know if anyone else has some insight.
Sent from my XT1585 using Tapatalk
Kalto
injection problem
Post by Kalto »
rebuilt the fuel pump??? mind have been rebuilt and been tested back after and its all good
archieim
Vehicle: 1994 Delica exceed
injection problem
Post by archieim »
I just got all my glow plugs replaced and had a fuel system flush, that ran the entire system including the injectors and pumps. The only thing that wasn't clean out was the gas tank. It starts and runs way better.
injection problem
The injection timing isn't usually all that sensitive- as long as the timing belt is correctly installed with all the pulleys pointing at their timing marks, and the injection pump is in the middle of its adjustment range, the engine should start and run just fine.
I would double-check the timing belt alignment, then try adjusting the injector pump timing to one end of the range, and then the other, and see if the issue changes.
Kalto
injection problem
Post by Kalto »
so i just found my probleme i got a air leak from my second fuel tank, dont know actually where but ill undo the fuel tank today
injection problem
How did you find the air leak?
Kalto
injection problem
Post by Kalto »
10 psi with a compressor in the air bleeder (the line who plugs directly in the frame )
injection problem
Clever! And watch for the fuel leaking out near the tank, I guess.
