I’ve been scouring the web in search of some aftermarket rims for my L400. lots with a 0 offset (ET0) but having lots of trouble otherwise. I have a 2” lift kit that is going to be installed soon and I’d like some bigger rubber to go along with it. Any help would be greatly appreciated!
						Available Rims in Canada
				manitoba
 - Vehicle: L400
				P.Gaudreault
 - Vehicle: Mitsubishi Delica 1998 Chamonix
I bought brand new rims from OK Tire. It's ION brand with 108 mm center hole, 6 bolts don't remember the offset but if my memory is good it is 40 mm offset.
Same model than this one.
https://www.ebay.com/itm/Alloy-Ion-Styl ... 1966306146
				manitoba
 - Vehicle: L400
thanks! i’ll have a look at them - what size of tire are you running out of curiosity?P.Gaudreault wrote:I bought brand new rims from OK Tire. It's ION brand with 108 mm center hole, 6 bolts don't remember the offset but if my memory is good it is 40 mm offset.
One thing that may help you is in "Useful Links For Vehicle Part Identification Purposes", located in the Delica FAQ Section. See if any of those match your stud pattern.
				manitoba
 - Vehicle: L400
Thanks, I'll have a look there
