Decoding the model number
trendkiller
Vehicle: 92 Super Exceed, CBR929RR
Post by trendkiller »
Howdy,
So I got my model number, it is P35 ()3()5467
but I could not find it on this list.
http://www.cars-directory.net/specs/mit ... ca/1991_8/
In fact, it isn't even close to anything on the list.
Any insite?
Thanks in advance,
Kelsey
BCDelica
Vehicle: WVO Powered Tuk Tuk
Re: Decoding the model number
Post by BCDelica »
Two reasons that's not working is; that number looks like the # just inside the door under the plastic and that web pages is for the 91 model year. The numbers on the list are from the plate with the model # below the little flap of carpet right below (and centered) the drivers seat.
Image Call me BCDelica-less
Post by Green1 »
only partially correct, that page is for vehicles manufactured after august 1991 and up until may 1994, so he was on the right page. the problem is as you pointed out, he needs the number from the VIN plate (not the VIN number)
marsgal42
Vehicle: The Mighty Gumdrop
Post by marsgal42 »
The number on the VIN plate will look like "Q-P35W HSRGT" - which says that Gumdrop is a Super Exceed with a crystal lite roof. There are other codes there for engine (4D56 for a turbo diesel), transmission (mine says "V4AW2 4875" - sounds like a final drive ratio), colour and options.
...laura
trendkiller
Right on!
Thanks for the replies guys!
Now I just to figure out how to take out my seat!!
hehe
I thought that would be too easy, having the number right under a little plastic plate......
39Ronin
Post by 39Ronin »
trendkiller wrote:Right on!
hehe
No need to take your seat out! Right behind where your legs are while seated in the drivers side, you will find a little piece of square carpet that flips up exposing your "vin" plate.
Post by Green1 »
I think you misinterpret what we mean by "below the seat"
sit in the seat as you normally would, and somewhere around mid-calf level, and centred between your legs you will find a flap in the carpet that lifts to reveal the VIN plate.
No dis-assembly required.
trendkiller
HEHE
Thanks for the directions!!
Kelsey
