Happy to give something useful back to this site that has proven helpful to me in the past :)
Developed a whining, almost gear like noise from the front of my 2nd gen L400 diesel. It was very obvious and was rpm related with a zzzZZZZZzzzZzz
quality to it. Took a while to pinpoint it, suspected it my be trans or timing chain related, finally upon startup it became your standard squealing belt noise, which upon popping the hood it was easy to see the tensioner pulley for the AC compressor was no longer turning. Voila! the culprit revealed!
Pulled the 14mm pulley bolt and there was the pulley and it's very replaceable and oh so common 6203 2rs bearing. These can be had almost anywhere for $5 to $10. I was quoted $165 plus tax for a new pulley from somewhere amazing ;)... but I hope you'll agree that for a $5.00 bearing and 5 minutes to press old one out and new one in that would be my chosen alternative. Note, this job made easiest by lifting (no need to disconnect) the intercooler up out of the way, disconnect top rad hose and slip out the plastic fan shroud off back side of rad.
whiny noise/failed AC belt tensioner/idler pulley
spaceguy
- Vehicle: mitsubishi delica
Return to “The Engine & Engine Electrical”
Jump to
- Delica Canada General
- ↳ Member Introductions
- ↳ General Discussion
- ↳ Events
- ↳ Events - Other BC
- ↳ Events - Alberta
- ↳ Events - Saskabush
- ↳ Events - Manitoba
- ↳ Events - Ontario
- ↳ Events - Atlantic Canada
- ↳ Events - North Of Sixty.
- Delica Canada Technical
- ↳ L300 Engine
- ↳ L300 Body
- ↳ L300 Overview
- ↳ A/C & Heating Systems
- ↳ Cooling & Oil Systems
- ↳ Intake & Exhaust
- ↳ Drive Train
- ↳ Front & Rear Axles
- ↳ Suspension & Brakes
- ↳ Body Electric
- ↳ Body General
- ↳ A/C & Heating
- ↳ Cooling & Oil
- ↳ Drive Train
- ↳ Body Electric
- ↳ Body General
- ↳ L300 Technical
- ↳ L400 Technical
- ↳ Delica Modifications
- ↳ WVO and Biodiesel
- ↳ Pajero
- ↳ Strada
- ↳ Mitsubishi Vanwagon
- ↳ Mitsubishi Kei
- ↳ Delica Wiki
- ↳ Radio Communications
- Sightings, Stories & Photos
- ↳ Was it You?
- ↳ Member Trips
- ↳ Member Rides
- ↳ Delica Photos
- ↳ On the Web
- Purchasing & Importing
- ↳ Tool Swaps, Share, Trade
- Feedback
- ↳ Archives
- ↳ Vehicle Sales
- ↳ Sales by Other Importers
- ↳ Sales by Private Members
