I have a ‘98 petrol v6 - here’s my problem:
So after replacing the timing belt ,water pump and rear camshaft seals attempting to start the vehicle it won’t start. Thinking we had possibly set the timing belt incorrectly we removed the front cover assembly to double check the timing marks line up correctly again. Yes they did. Tested the for spark at each coil. Found we only had spark on 1 coil on both leads (waste spark system). Swapped 1 coil in the “pack” to the position of the coil that produced spark then that coil had spark. Tested continuity of wires from the power control unit to the coils-good. Power to the coils good. Harness side of the crank and camshaft position sensors ground wire to batter 2 ohms resistance. -good. Battery voltage at other wire (with key on). Suspecting bad camshaft position sensor. Tried to scope for signal could not get a good signal.
Any advice on how to fix this would be greatly appreciated!!
Won’t start :( need help!
manitoba
- Vehicle: L400
Jump to
- Delica Canada General
- ↳ Member Introductions
- ↳ General Discussion
- ↳ Events
- ↳ Events - Other BC
- ↳ Events - Alberta
- ↳ Events - Saskabush
- ↳ Events - Manitoba
- ↳ Events - Ontario
- ↳ Events - Atlantic Canada
- ↳ Events - North Of Sixty.
- Delica Canada Technical
- ↳ L300 Engine
- ↳ L300 Body
- ↳ L300 Overview
- ↳ A/C & Heating Systems
- ↳ Cooling & Oil Systems
- ↳ Intake & Exhaust
- ↳ Drive Train
- ↳ Front & Rear Axles
- ↳ Suspension & Brakes
- ↳ Body Electric
- ↳ Body General
- ↳ A/C & Heating
- ↳ Cooling & Oil
- ↳ Drive Train
- ↳ Body Electric
- ↳ Body General
- ↳ L300 Technical
- ↳ L400 Technical
- ↳ Delica Modifications
- ↳ WVO and Biodiesel
- ↳ Pajero
- ↳ Strada
- ↳ Mitsubishi Vanwagon
- ↳ Mitsubishi Kei
- ↳ Delica Wiki
- ↳ Radio Communications
- Sightings, Stories & Photos
- ↳ Was it You?
- ↳ Member Trips
- ↳ Member Rides
- ↳ Delica Photos
- ↳ On the Web
- Purchasing & Importing
- ↳ Tool Swaps, Share, Trade
- Feedback
- ↳ Archives
- ↳ Vehicle Sales
- ↳ Sales by Other Importers
- ↳ Sales by Private Members
