Remove Second Row Cigarette Lighter ????
Delicatessan
Vehicle: Delica L300 ‘93
Post by Delicatessan »
I want to remove my second row cigarette lighter. I can't figure out how to un-attach it. Has anyone done this?
Did you figure this one out? I removed mine so long ago I don't recall how it worked, but I'm curious. Most cigarette lighter sockets you unscrew the metal can/housing on the back.
Delicatessan
I have disconnected it for now. That was easy. I just removed the ash tray and the deeper tray next to it and that gave me enough access to disconnect the wires. Since then, I’ve been pretty busy. I don’t quite have enough hand access to loosen the lighter from that position. So I’m probably going to have to remove panels (ugh). Will update when I tackle.
Oh, you're absolutely going to have to remove the panel. The screwed-on can around the lighter sockets are usually super tight, there's no way you'll unscrew it with fingertips.
