Rear coil spring spacers
Rear stabilizer arm spacers
Rear brake line spacer
Front ball joint spacers
All required bolts, washers and lock washers
Spacer material is aluminum.
The front ball joint spacers are tapered and have a through hole for grease nipple access
The bolts are all metric class 8.8 (120,000 psi tensile strength).
The price is $500 plus shipping (somewhere between $30-40 standard shipping in Canada) email transfer is preferred.
See the following link for more info on L400 lifting: viewtopic.php?f=10&t=8204&p=62789&hilit ... ood#p62789
Send orders and questions to stefan at wolframtools dot com - I dont often check my PMs.
Also check out my company website: http://wolframtools.com/products.html
