Hey everyone!
I am having some issues with a 1994 L400 V6, ignition coil pack #3 is not firing! Power to the coil is ok and the coil has been swapped with a known good coil pack and #3 ignition coil does not fire still. it would appear that the ECU is not sending a signal to the power transistor for ignition coil pack #3. The confusing part is that I have swapped out the power transistor and ECU from a 1996 L400 with no change, each component individually and also together. Wiring resistance is OK at 0.4 ohms, I am getting a constant output of 0.045v from the ECU to ignition coil #3, #1 and #2 get 0.300-0.400v at idle and increases with RPM(approx 0.600v around 2000rpm).
Does anyone know if there is a certain input to the ECU that will override firing one of the coil packs? I thought possibly excessive knock signal shutting down a cylinder but there is only one knock sensor so I am not sure if it would do that. A bad cam or crank sensor would affect all coil packs, throttle position sensor would affect timing which again shouldn't single out one coil pack.
Dead coil pack
YawoFamVan
- Vehicle: '94 L400 PF6W
Jump to
- Delica Canada General
- ↳ Member Introductions
- ↳ General Discussion
- ↳ Events
- ↳ Events - Other BC
- ↳ Events - Alberta
- ↳ Events - Saskabush
- ↳ Events - Manitoba
- ↳ Events - Ontario
- ↳ Events - Atlantic Canada
- ↳ Events - North Of Sixty.
- Delica Canada Technical
- ↳ L300 Engine
- ↳ L300 Body
- ↳ L300 Overview
- ↳ A/C & Heating Systems
- ↳ Cooling & Oil Systems
- ↳ Intake & Exhaust
- ↳ Drive Train
- ↳ Front & Rear Axles
- ↳ Suspension & Brakes
- ↳ Body Electric
- ↳ Body General
- ↳ A/C & Heating
- ↳ Cooling & Oil
- ↳ Drive Train
- ↳ Body Electric
- ↳ Body General
- ↳ L300 Technical
- ↳ L400 Technical
- ↳ Delica Modifications
- ↳ WVO and Biodiesel
- ↳ Pajero
- ↳ Strada
- ↳ Mitsubishi Vanwagon
- ↳ Mitsubishi Kei
- ↳ Delica Wiki
- ↳ Radio Communications
- Sightings, Stories & Photos
- ↳ Was it You?
- ↳ Member Trips
- ↳ Member Rides
- ↳ Delica Photos
- ↳ On the Web
- Purchasing & Importing
- ↳ Tool Swaps, Share, Trade
- Feedback
- ↳ Archives
- ↳ Vehicle Sales
- ↳ Sales by Other Importers
- ↳ Sales by Private Members
