Space gear 2002 V6 3.0L Gas, accélération problem
Boriscool
Vehicle: Delica Space gear
Post by Boriscool »
I have a problem with my delica 2002 space gear gas. When I try to accelerate, it is sometimes hesitating, like if the connection with the fuel was blocked and there is no gas going to the engine . It’s not consistent. But I change the fuel filtrer and it’s still doing it. What would be your diagnostic?
Ralph in Winnipeg
Vehicle: 94 Strada
Post by Ralph in Winnipeg »
Lots of options. Good to change the fuel filter. How is the fuel, has it been sitting or just come off the boat? Maybe run some injector cleaner through. How's the air filter? No air in means less acceleration. You might want to clean the throttle body. Is the check engine light coming on? You could scan it as well.
Ralph in Winnipeg
