I tried to install a (4d56) and its drive system Aisin 30-43le on a Ford T350. I don't know if it can bear enough torque.
Is your l300 using Aisin 30-43? How much torque can Ericsson 30-43le withstand 400nm? 300nm?
My rear differential speed ratio is 3.73
- Vehicle: xml6125hev93c
Autocorrect?
L300s (the boxy shaped Delicas, from 1988 to 1996) use an Aisin 03-72L. If you've got an LE it's from something else.
The 03-72L was also known as the Toyota A44DL. It was only fitted to vehicles with torque output up to 200Nm (Montero 4D56 Turbo, Volvo 940 GLE 16-valve).
The 03-71 (Toyota A43D) is the same shape and should fit to a 4D56, it's a non-lockup transmission and was fitted to the Volvo 940 2.3 Turbo making 265Nm.
I can't find any instance of an Aisin 03-7X transmission being used on anything with more than 300Nm.
I change my transmisson .For TRANSIT T350 VAN, it have 3000kg
IF 4d56 get 100kw 300nm + 30-43LE can work?
Is there any way to increase the power without increasing the torque and reach 90 or even 100kW at the limited speed of 4d56 of 2000 +? Can my 30-43le transmission cooperate actively
I don't know the 30-43LE transmission, I only know Delica transmissions, sorry.
