4m40 mystery noise
chuvsta
Vehicle: 1994 Delica L400 Exceed
4m40 mystery noise
Post by chuvsta »
Hey all,
I am new to the Canada forum so thank you for allowing me to be apart of this awesome resource. I just recently made the switch from a '93 L300 to a '94 L400. I have been hearing what almost sounds like a metallic slapping a noise coming from what seams like around my alternator, it is very pronounced at start up when cold and then after a few minutes it almost completely goes away. My first thought was timing chain rattle or maybe tubo, I did the old mechanics trick of putting a screwdriver to the timing cover in a few spots and putting my ear against it and from I could tell the sound wasn't coming from there. Haven't had time to take a look at the turbo. The previous owner replaced the alternator a few months back and didn't notice the sound until a few weeks ago before I purchased the van. Any insight is greatly appreciated. I have attached a video of the sound at startup and then after a few minutes.
https://youtu.be/t_5sBiLSe80
https://youtu.be/uxDbGgwLfp8
poochike
Vehicle: 1999 L400 Chamonix Gen2
4m40 mystery noise
Post by poochike »
Alternator could be loose. The mounting bolt is tough to get at and is often under torqued. Good place to start. While you're down there check for play on the turbo spool.
chuvsta
4m40 mystery noise
Post by chuvsta »
poochike wrote: Wed Jul 29, 2020 1:03 pm Alternator could be loose. The mounting bolt is tough to get at and is often under torqued. Good place to start. While you're down there check for play on the turbo spool.
Sounds good, I'll crawl under some time this week and take a look! Thanks.
