The conclusion from many hours of head scratching and scraped knuckles is that L400 front hub assemblies would be SO cool on an L300 if only they didn't throw the camber out by a CRAZY amount! They would give a standard L300 a 1" lift and sharper/more responsive steering.....but unfortunately, the built in alignment of the top knuckle arm meant there is no way you could adjust the camber into anything sensible! :( :(
L300 VS L400 hub & knuckle:
L300 height:
L400 height:
Nearly 1" of lift between the two.....but it's a real shame that the L400 hub throws the camber out by this much AFTER adjusting the camber to its max....
Bearings from most models seemed fairly interchangeable except for the front hub rearward wheel bearings from an L400 and 2.8 Pajero which are larger for some reason?? My car is now running a combination of Pajero, L400 and L300 bearings due to mine exploding after the auto free-wheel hub decided to retire on me. I've also stuck the hub/driveshaft end plates from a 2.8 Pajero on until I can get some decent manual locking hubs. My front drive shafts are now constantly engaged, but that is better than the self-destructing Auto hubs and will do until I sort the manual ones out.....
One lovely mod for any L300 owner to consider is to replace the standard single piston calipers with twin piston ones from the MkII 2.8 Pajero or L400. These calipers are notorious for siezing up (slide bolts AND pistons!!) but if they are free moving and not corroded, then fitting a set is well worth while due to the extra braking you can get from them.
Look at the difference between the 2.5 caliper (on top of the upper wishbone) and the 2.8 one:
Here is the finished mod....and quite an improvement over the original brake power although I suspect I'll be having to keep a closer eye on the pistons because they are more likely to sieze than the L300 ones.....having said that, with the way I drive, there is no way these pistons will have chance to sieze!
2.8 Paj caliper on the L300 knuckle:
2.8 Paj caliper with trimmed L300 disc backplate and L300 hub & disc:
You need to cut some of the brake disc back plate away to enable them to fit, but I can confirm the following set-up for anyone thinking of upgrading their brakes?
Hub: Standard L300
Knuckle: Standard L300
Disc: Standard L300
Disc backplate: Modified L300
Caliper: 2.8 Paj or 2.8 L400
Caliper carrier: 2.8 Paj or 2.8 L400
Pads: 2.8 Paj or 2.8 L400
It's a basic 'plug & play' caliper/carrier swap, but you'll need to remove/replace the L300 back plates for trimming/shaping before being able to bolt the calipers straight on. The Paj/L400 caliper carriers are a perfect match for the L300 knuckle!!! :D Make sure you give any 2nd hand calipers a good overhaul before attempting to fit them on your pride & joy!!
Hopefully this info will be of some use to some of you L300 owners??
I drove 60+ miles home last night....and considering I am still bedding in the new pads, the brakes felt very responsive and more positive. I can't wait until they have bedded in properly....stoppies here we come!!
