does anyone have a used motor for sale 2.5 turbo
martybc
Vehicle: 92 exceed
Post by martybc »
hi there does any one have a used motor for sale I blew a rad hose and blew the head gasket
I need to get back on the road for shambhala in two week
help
thank marty
Re: does anyone have a used motor for sale 2.5 turbo
Post by Green1 »
it would seem to me that if it's only the head gasket, a new motor is way overboard... talk to ccautos, mardydelica, or rocky mountain imports about a new head gasket. they run less than $100 instead of several thousand for a replacement motor.
Even if it turns out the whole head is cracked, that's still cheaper than a new motor (the heads run about $1600 new, or approx $700-$800 for a used one)
both of these repairs can even be done without removing the engine from the vehicle. (which will save you significantly more money again)
The big question will be WHY you overheated in the first place, when the rad hose blows it's usually an indication of too much pressure in the coolant system, often due to a cracked head or damaged head gasket due to previous overheating, if the vehicle has a history of overheating you should definitely check the radiator, water pump, and thermostat to make sure that they are good too (many of these vehicles arrive with completely clogged radiators) I strongly recommend you look at addressing these problems at the same time or you risk going through the whole mess again soon...
Good luck with the repairs, and hopefully you'll be on the road again soon!
ccautos
Vehicle: 92 Delica SE
Post by ccautos »
I have complete engines , short engines , cylinder heads , headgaskets , rebuilt radiators , rebuilt injectors , rebuilt fuel pumps , rebuilt alternators and almost anything else you could possible need to repair a Delica and it is all in stock ready for delivery . Call for more details . (250)954-2157 or e-mail ccautos@telus.net . Thanks , Glen
