This is the second time in the last 6 months that my alternator wire connector has broken off. The first time the original flimsy connectors broke
, I replaced them with a single battery terminal connector crimped and soldered... now that broke
. Now I have separated the wires again and went with two individual crimped and soldered battery terminal connectors. Hopefully this holds, has anyone else had this problem?
On a side note, the first time the connectors broke I also discovered the adjustment arm for the alternator snapped at the engine block but it stayed in place long enough until I got a replacement from CCA. I also ended up going with a smaller set of belts since that held the alternator closer to the engine and would cause less stress on the arm.
If any of that makes sense
