E-Brake light
Katabatic
E-Brake light
Post by Katabatic »
My dashboard E-brake light has now decided to stay on when the brake is disengaged. It sometimes flickers when i go over bumps, This is most likely some kind of loose conection... is it easily fixed? anybody know?
Re: E-Brake light
Post by Green1 »
As the general consensus appears to be that I do not know what I'm talking about, and cause more harm than good, I am removing this post so that others are not tricked in to following my ill-advised instructions.
loki
Re: E-Brake light
Post by loki »
Katabatic wrote:My dashboard E-brake light has now decided to stay on when the brake is disengaged. It sometimes flickers when i go over bumps, This is most likely some kind of loose conection... is it easily fixed? anybody know?
yep that light is also a general brake system warning light as it is on most vehicles, with the going off going over bumps I would agree that your brake fluid is low.
Katabatic
Re: E-Brake light
Post by Katabatic »
Duhh, sounds so simple! and yes thats what it was, Thanks!!!!
I'm not always so sharp by the way!
Re: E-Brake light
Post by Green1 »
Glad you got it sorted out, and don't feel too bad about it, the first time I had those symptoms I had to ask the forum too!
