Valve cover gaskett
northvanmatt
Vehicle: 91 super exceed
Valve cover gaskett
Post by northvanmatt »
Good day all I was wondering if any one has a part # for a valve cover gaskett and if the gaskett comes with the two plugs that go on each end.
mine leaks a VERY tiny amount. If it was any other car I probably wouldn't fix it but I want to maintain my new delica to the highest standard :D
cheers
matthew
BCDelica
Vehicle: WVO Powered Tuk Tuk
Post by BCDelica »
Sorry I don't have a part number but you may want to try Milner's.
http://www.milneroffroad.com/delica.htm
And there's gasket part numbers here - viewtopic.php?t=369, doesn't say what gasket though!!
Cheers!
Kev
Image Call me BCDelica-less
ccautos
Vehicle: 92 Delica SE
valve cover gasket
Post by ccautos »
I know the Felpro number that includes the rear semi-circular plug but not the top taper plugs . Call me for more information .
delica_crazee
Post by delica_crazee »
hey hey NVMatt, I know exactly the part number you are looking for as I had the same problem... I'm not going to tell you , though, 'cos I'm weird like that. Good luck. :wink:
BCDelica
Post by BCDelica »
Come on, PM him you don't want to share.
The great thing about this forum is the sharing of all things to better our Deli's.
northvanmatt
delica_crazee you are crazy. I can't tell if you are joking or not. you did the same thing to me in another post about mirror arms. I have solved my gaskett problem thankyou to all who replied mardy delica was able to source out and original delica gaskett, got it swapped already :D
cheers
matthew
