For sale: Filtered WVO in Vancouver
- delicat
G'day all,
I have close to 300 gallons of very nice filtered/de-watered WVO for sale. I've been too slow to complete my Veggie install on my trucks so my reserve keeps growing up on me...
If you don't have a WVO install done on your truck you can still blend it with your diesel but only to a max. of 25%. I've been running it that way for 6 months and works great. With colder weather I might reduce the % a bit but doesn't get really cold here anyway.
It's $12/cube (approx. 5 gallons/20 litres) or $50 for 5.
David
David
Re: For sale: Filtered WVO in Vancouver
David,
I'll take a bunch off your hands.
PM sent.
PM sent.
- Vehicle: -
David,
Our Dino is thirsty and want some homemade WVO too.
Just finished painting our new jerry can from Jay....in Delica white :) So we probably come by soon...
- delicat
Jesse, fexlboi...
No prob, just phone me or PM back. I seriously think I have enough for everyone!
fexlboi, nice job on the jerry can. Your other pictures look great as well, love those old water house and that monster camper!
- konadog
- Vehicle: 1992 GLX L-300
delicat wrote:If you don't have a WVO install done on your truck you can still blend it with your diesel but only to a max. of 25%.
WEO and WTO too - waste engine oil and waste transmission oil. At least, that's what I've read elsewhere. Never more than half though, too thick otherwise.
I've been pouring the engine oil into the tank, and I'm interested to see what the fuel filter looks like when I change it in a month or so. And I'm just about ready to do another oil change, so that'll be three, if not four...
- Golf Cart
- Vehicle: 1992 Exceed
Your Delica oil change oil, or oil change oil from a gas pot ? Now you have me thinking. Will definately up your sulphur content of the diesel ( increased slipivity ) but curious on what it will do to injectors with a higher carbon count on such a small amount of diesel. Adding 2-3 ounces of 2-stroke motor oil will up the sulphur content. I'll call our lab that tests fuel in the morning.mararmeisto wrote: I've been pouring the engine oil into the tank, and I'm interested to see what the fuel filter looks like when I change it in a month or so. And I'm just about ready to do another oil change, so that'll be three, if not four...
Oil from my own machine - not ready to ask the oil change shop down the street for a 50 gallon drum of it. I want to get a centrifuge first.Golf Cart wrote:Your Delica oil change oil, or oil change oil from a gas pot ? Now you have me thinking. Will definately up your sulphur content of the diesel ( increased slipivity ) but curious on what it will do to injectors with a higher carbon count on such a small amount of diesel. Adding 2-3 ounces of 2-stroke motor oil will up the sulphur content. I'll call our lab that tests fuel in the morning.
- after oil
thats true, myself and 2 other powell river delicas ran 50/50 in the summer, all goodkonadog wrote:I had heard up to 50% in the summer months - Pretty sure that's what after oil did - is that right after oil? I
i borrowed ccglens van tuesday while his crew was doing some stuff on mine. he had diesel blended 70/30 with WVO
ive read that WEO breaks down when its being used in the engine.mararmeisto wrote:WEO and WTO too - waste engine oil
"Breaks down"? Does that mean burn? Most everything breaks down if one applies enough heat to it.after oil wrote:ive read that WEO breaks down when its being used in the engine.
Considering diesel fuel is still an 'oil' while gasoline is a 'refined spirit', I would think there would be not much difference burning a slightly thicker oil than burning straight diesel. The limitation to filling the fuel tank completely with WEO is that the fuel pump can't suck it outta the tank (same reason for WVO). By the time the engine is warm, the IP is warm enough too, and this resident heat is enough to heat the fuel/oil mix before it hits the injectors. This underlying reason is why I've never put more than 20 litres of either WEO or WVO into my nearly empty tank before topping off with diesel.
Back on the original topic: anyone coming to the Island this weekend, could bring me a couple of cubes (like 4 maybe)? Delicat, if that happens what would be my cost? PM me if this is to happen. I've got two empty cubes I could send back with whomever.
- Vehicle: -
By the way is it still a good idea to add diesel conditioner if we mix the diesel with WVO?
- delicat
I do, don't know if I'm wasting my time but don't think it can hurt. Usually they contain some form of biocide or the like to get rid of any water that might be in your fuel so that's good. Some claim to increase your Cetane, can't hurt although minimal. The WVO surely adds lubricity to the mix, same as the additive so you might not need as much if you use WVO.
I don't have any hard facts behind all this, it's just what I think so take it for what it's worth. All I know is that my trucks run real nice since I started using WVO in my diesel (and smells nice too!) but I never over did it, 20-25% max for me (1 jug per full tank). You can get away with more in the hot summer months but not worth the risk for me.
If anyone needs some I should be home Sunday morning until noon, feel free to drop by.
