and the compass works great!!
the thermometer is 50/50, the INSIDE temp seems correct but the OUTSIDE temp shows 63'C ??!?!
i'm not sure where the outside sensor is... anyone??
Nice job!!mararmeisto wrote:Capacitors are usually the culprit in older electronics: the dielectric dries up or leaks out. Either way, the capacitor no longer stores charge, which throws off the circuit. Good job. Who's got the gold stars?
Not sure where the outside thermometer is located - don't have one of those pods.
well i've found the "little rubber house" and everythings seems to be in order, i'm up at Big White where it consistently -15 or so. when i turn the ignition on, the inside Temp shows -10'C, and when i change it to outside, it says 60'C..... anyone have an idea what might be going on? maybe one of the Cap's i replaced was overheated and failed when i was soldering them to the board??...... a connection somewhere?The outside temp sensor is in a little block of rubber right behind the front bumper. I wanna say LHS, but its been a while since I looked at it. In any event, its in the neighbourhood of the protruding cap, toward the center, where the plastic meets the metal, behind there in its little rubber home...
