nxski wrote:Another thing to remember when using a manual switch is that if you are wiring directly from the battery (as some have done) you are better off with 12V, no matter what year your vehicle is.  If you are wiring through the relay / drop down resistor (the safe way to wire the system) then you want to stick with the 6.2V and you will have to hold the manual switch for about 15 seconds per cycle to get them warm enough.  You can also wire through the 12V relay which I've been told you can do with either 6 or 12V plugs but you will be more likely to burn out the 6V ones just as would be the case wiring directly from the battery but with an added 'click' to tell you they're getting power...  If you are putting more voltage into a lower voltage plug you will want to be very careful not to hold the switch on for too long.
Please correct me if this information is not completely accurate as in this matter a mistake can be costly!
If you have a manual switch due to faulty 6.2 V control system, 11V glow plugs are way better than 6.2V GPs.
There’s no way to know the optimum engine temperature for perfect starting in primitive manual switch.
That means GPs are getting too hot for extended time , that leads burning too quickly and buying new ones frequently.
You may need GPs every year or even faster due to hard starting.
We have too many threads for restoration broken ECU ( 6.2V super quick glow plug system ) in this forum.
Try to restore that one and go to Mitsubishi OEM GPs, or you may think conversion “11V self regulating glow plug system”.
Fortunately we have a Mitsubishi OEM GPs group buy opportunity ( $70-80 for 4 ) here and still on going.
http://www.delica.ca/forum/group-buy-oe ... 11963.html
jfarsang wrote:They are small enough to ship them air. I'm expecting the quotes first week of Dec. I'll post them in the first thread and the people on the list can vote on which price point/shipping is the most cost effective/convenient. Once that's sorted, I'll get the funds from everyone, wire it over and then wait patiently until they arrive. I will be shipping them across Canada as well to those that cannot pick them up.
Here are recent debate for related topic.
http://www.delica.ca/forum/glow-plugs-again-9412.html
http://www.delica.ca/forum/hkt-glow-plu ... 10081.html
http://www.delica.ca/forum/glow-plug-rant-12035.html
Steven
