Is it possible to adjust the front windows?  Mine tend to fall forward a bit causing the window to come up on a bit of an angle.  So when it's finally closed there is a gap on backside.  Is there anyway to fix this?
Muzzy
						front window adjustment?
- Golf Cart
 - Vehicle: 1992 Exceed
Re: front window adjustment?
Sounds like the window needs an adjustment at the track/glass location. Thats a door card off job. Not too too dificult. You need to be a little cautious when popping the snaps on the door card. I replaced my window motor. Job took a better part of an hour first time.
Good Luck
							Good Luck
