Useful Part Numbers
Useful Part Numbers
*Prices are in UK £'s otherwise ea part #'s can be cross-checked and verified
Full Compliments and thanks to all who have/will supply part numbers
MU840022 - 100 a fuse £ 5 – 12 )
MF241313 - 12 x 40 bolts exhaust fitting £1.63
MR151285 - 31mm front anti roll bar bushes ea £3.91+
MR192015 - 650 wiper assembly £23.72/pair
MR360148 - A/con belt £ 9 – 32 )
MH014054 - Alt belts pr £ 14 – 68 ) (supercession from mh 014051)
MR267370 - Auto gear selector (app £90gbp)
XD310484 - Balance belt £26.66 each
MB882036 - Black clips and rubber covers to lock back windows
MB584750 - Bolt hub £1.91
MB886676 - Boot kit doj f/axle £46.92
MR167722 - Bulb dash illumination £2.67
MR167724 - Bulb instrument panel (warning lights) £2.53
ME200491 - Centre bolt£ 4 – 87 )
MR727105 - Centre console htr radio control £124.60+
MR720570 - Centre console l400 £85.00ish approx
ME190016 - Chain tension guide (fixed) £36.45
ME190013 - Chain tension guide (tensioner side) £34.18
MD313660 - Comes as 2 belts for fan £15.11 each
MR175492 - Compass bulb £ ?
MR720572 - Cup holder (front) £68.04 inc vat
MR167725 - "D" light bulb £3.00
MB619578 - Diamond badge set (3 sets of diamonds) £12.99
ME201700 - Diesel pump £3494.81 yes £3494.81 inc vat, 94 lwb royal
MR204842 - Element air cleaner £38.34
MR353425 - Front adj shock absorbers £146 inc vat
MB618228 - Front bottom £7.84
X3511003 - Front brake pads £51.19
MB618227 - Front caliper slider bolt
MB624908 - Front disc wheel holder £15.43
MB476821 - Front grill clips (the plastic clips that hold the grill on) £0.60
MR112711 - Front lower sus bushes £18.99
MR112710 - Front lower sus bushes £18.99
MR196836 - Front prop shaft (4wd) universal joint(£45.00+vat)
MB618227 - Front top £8.79
XB220900 - Fuel filter £19.69
ME201998 - Fuel pump for 94 l400 (check to confirm individual types)
MD050317 - Gasket o/drain plug £0.54
MD727105 - Gauge water temp (dash panel) £28.14 +vat
MD337888 - Glow control relay (£38 millfields autoparts)
ME202443 - Glow plug bus bar £6.98
ME200970 - Glow plugs £41.21 each
MR727168 - Guttering trim moulding clip £6.55 +vat
MR129007 - Handbrake cover £20.58 (special order)
MR149203 - Hazard light switch £30.77 inc vat
MD020233 - Head bolt washer £1.20(4m40 head)
MR416912 - Headlight washer pump £97 + vat
MR192417 - Indicator/sidelight unit l?
MR192418 - Indicator/sidelight unit r?
MB326019 - Instrument nut 76p (captive nut)
MR115680 - Joint RR Heater Pipe
MR175427 - L400 aircon receiver dryer £80.79 inc vat
MB924891 - L400 header tank £ ?
MB877848 - Light lens for sliding door footwell lamp .£5ish
MD970389 - Liquid gasket (for timing chain cover) £42.43
MR112711 - Lower wishbone bush (back part of wishbone) £17.59
MR112710 - Lower wishbone bush (front part of wishbone) £17.59
MB957431 - Muffler exh rear section inc box £151.92
MB952637 - N/s mirror to door trim (vertical) £14.51 + vat
ME088532 - Oil filter £27.40
ME200028 - Oil seal £ 19 – 63
MB942997 - Original keyfob for alarm £260ish
MR502584 - Original keyfob transmitter case £18.00ish
MR502590 - Original keyfob transmitter case £18.00ish
MH035529 - O-ring (thermostat housing chain cover) £2.88
ME200414 - O-ring (water pump to chain cover) £5.09
MR167676 - Perspex combination main dash clock cover price £52.91
MB857837 - Piston front wheel £31.03 (2 per side+vat)
MD180581 - Power steering belt £6.82 each
MR126103 - Radiator (genuine) £250 + vat
MR267684 - Rear anti roll bar bushes £4.17 each + vat
MR267684 - Rear anti roll bar bushes £4.76 each
MB699585 - Rear bottom £7.84
MR112385 - Rear Shock L400
MR192449 - Rear nozzle for wash/wipe. Price £7.57 + vat
MB699584 - Rear top £7.84
MR110859 - Repair kit boot bj £46.92
MR727138 - Roof gutter 2 piece
MR727150 - Roof gutter 2 piece
MR161679 - S timing chain guide £ 37.98 +vat
MN117368 - Screws for the s timing chain guide
MB857840 - Seal kit front brake calliper £27.47 (1 for each side+vat)
MR122305 - Speed sensor (gearbox) (£105.00+vat)
MR111098 - Speed sensor drive cog (£19.00+vat)
MR151976 - Steering gator (bellows) £24+vat
MB951788 - Steering joint shaft
MR234642 - Sump guard / bash plate £61 +vat
MF240055 - Sump guard bolts £0.66p each
MD620874 - Throttle position sensor £200.13 inc vat
ME200244 - Timing chain £101.69
ME190016 - Timing chain guide £ 40.50 +vat
ME200248 - Timing chain tensioner £ 66.64 +vat
MR151971 - Track rod/tie rod £52
MR105741 - Tray, bat tray, battery
MC994292 - Universal joint kit about £50 +vat
ME200339 - Washer £ 5 – 22 ) +vat
3880A008 - Wheel nut £2.44
MMB922064 - Dust cover £7.48 (each) +vat (Track rod end rubber boot)
MR281671 - top hose to radiator £12-23 inc
MR298583 - hand grip roof inside £32-70 inc
MR712796 - end cap that fits on hand grab rail by sliding door £1-10 plus vat
MR166198 - sensor A/T speed £115-04 inc
MB957433 - Rear Exhaust for LWB £161-16 + VAT
MB687002 - GASKET FOR EXHAUST £2-76 + VAT
ME201328 - Pipe(thermo housing to cyl head) £32ish inc vat
MD030763 - O-ring for above pipe also for heater return pipe £3 inc approx
MB857613 Rear brake piston,one each side
MB857612 Seal kit for above
MB270012 Bonnet stay clip
MB618227 Sliding caliper bolt, Front one each side
MB618228 Sliding caliper bolt, Front one each side
MB858395 Support Carrier Front Caliper Left?
MB858394 Support Carrier Front Caliper Right?
MB927686 Nylon Roller for sliding door, 2 needed
MF660066 Front axle sump plug washer/gasket top/filler= copper £1.35
MD000312 bottom/drain steel
MD 951857: part number for sump bolt
MD 951858: sump bolt washer
MC840219 Oil pressure switch/sensor £11.02
MR201040 Water heater hose 'T' piece situated in engine bay immediately behind battery position with two spigots of one diameter and 1 of a smaller diameter (there are 2 per Deli, 1 in the flow and 1 in the return)
MF BOLTS 12X40 FOR EXHAUST £1-72 EACH + VAT
NON-OEM-PART NUMBERS
ADC44243 - BLUEPRINT ADL REAR BRAKE PADS L400 (Excellent Stopping Power)
ADC44250 - BLUEPRINT ADL FRONT BRAKE PADS L400 (AS ABOVE)
ADM58151 - BLUEPRINT ADL INNER CV BOOT
ADC42232 -Blueprint £32 . Air Filter
ADC42117 - 188m Oil Filter ADL £23
ADC 41803 - ADL Glow Plug £14 each (Also available from club shop check price)
GFE7029 - Fuel Filter £14.20
GBP910AF - Front - Unipart Brake pads
GBP1059AF - Rear Unipart brake pads
BG3115 - Delphi Lockhead Front Brake Disc
62855 NISSER RADIATOR Price £148.00 + VAT) Wessex Radiators burseldon
CMB13003 same as the shogun 2.8
The Thule 426 system is for the delica 94 on high roof and cost £72-56 inc when ordered from Halfords, delivery about 3 working days.
The Thule 425 system is for the standard roof Delica 94>
Polyurethane bushes from milners www.milneroffroad.com
002027K - Front Anti Roll Kit (2 middle bushes)
004653K - Rear Anti Roll Bush Kit (centre bar size 23mm)
004654K - RearAnti Roll Bush Kit (centre bar size 25mm)
Lewis has been kind enough to provide these part numbers as well. Some are updates with approximate pricing etc... Cheers - Rusty
MB927593 - Left Hand Sliding Door Handle
MB954865 - Remote locking keyfob transceiver, Type G8D-280M-B17
MR267538 - Shock Absorber Rear (ECS type) L400 £68.39 + vat (Each)
MR353425 - Shock Absorber Front (ECS type) L400 £68.39 +Vat (each)
MF430123 - Nut (12), to fit shock absorber lower mount £00.32 + VAT (Each)
MS450044 - Spring Washer to fit Shock absorber lower mount £00.15 + VAT (Each)
MU100015 - Bolt, to fit shock absorber lower mount £2.75 + VAT (Each)
MR195468 - AT TRANSMISSION BOX SWITCH, T/F GEARSHIFT 4WD L (Special Order) £40.39+VAT (Each)
MB896029 - AT TRANSMISSION BOX SWITCH, T/F GEARSHIFT 4WD L £41.99+VAT (Each)
MB837110 - AT TRANSMISSION BOX SWITCH, T/F G/SHF H-L LAMP £41.99+VAT (Each)
MR195470 - AT TRANSMISSION BOX SWITCH, T/F GEARSHIFT 4WD L (Special Order) £39.99+VAT (Each)
MB837108 - AT TRANSMISSION BOX SWITCH, T/F GEARSHIFT 4WD L £41.99+VAT (Each)
Note prices for both front lower wishbone bushes (L400) are £23.00+VAT (Each)
To save you some time hunting through I have marked them below with a * (NB: I put them in parts number order for easier comparison):-
MB270012 - Bonnet stay clip
*MB618227 - Front caliper slider bolt
*MB618227 - Front top £8.79
*MB618227 - Sliding caliper bolt, Front one each side
*MB618228 - Front bottom £7.84
*MB618228 - Sliding caliper bolt, Front one each side
*MB699584 - Rear top £7.84 ------- Description matches MB618227 (above)
*MB699585 - Rear bottom £7.84 ------- Description matches MB618228 (above)
MB857612 - Seal kit for above
MB857613 - Rear brake piston,one each side
MB857840 - Seal kit front brake caliper £27.47 (1 for each side+vat)
MB858394 - Support Carrier Front Caliper Right?
MB858395 - Support Carrier Front Caliper Left?
MB927686 - Nylon Roller for sliding door, 2 needed
MC840219 - Oil pressure switch/sensor £11.02
MD000312 - bottom/drain steel
MD951857 - part number for sump bolt
MD951858 - sump bolt washer
*ME190016 - Chain tension guide (fixed) £36.45
*ME190016 - Timing chain guide £ 40.50 +vat
MF660066 - Front axle sump plug washer/gasket top/filler= copper £1.35
*MR112385 - Rear Shock L400 ?
*MR112710 - Front lower sus bushes £18.99
*MR112710 - Lower wishbone bush (front part of wishbone) £17.59
*MR112711 - Front lower sus bushes £18.99
*MR112711 - Lower wishbone bush (back part of wishbone) £17.59
MR192417 - Indicator/sidelight unit left?
MR192418 - Indicator/sidelight unit right?
MR267370 - Auto gear selector (app £90)
*MR267684 - Rear anti roll bar bushes £4.17 each + vat
*MR267684 - Rear anti roll bar bushes £4.76 each
*MR353425 - Front adj shock absorbers £146 inc vat
*X3511003 - Front brake pads £51.19 --- Suspect code should be 'XB' not 'X3' ie 6 figures
Blackberry
Vehicle: '92 Exceed P35W
Re: Useful Part Numbers
Post by Blackberry »
Hmm...are any of these part numbers for P25/P35 4D56T models?
Does the L400 2.8 use a timing chain?
Blackberry wrote:Does the L400 2.8 use a timing chain?
Yep
Van Diesel
Vehicle: 94 Space Gear
Post by Van Diesel »
Where does one take the above mentioned parts numbers? Can local shops provide any of these parts or do you have to contact someone in the UK?
Thanks.
