Wheel well flares wanted to BUY
Moderators: delicanuck, mark
glazediggy
Vehicle: Nissan Pathfinder
Post by glazediggy »
Hi all,
I am interested in buying 4 wheel well flares (the ones that go around your wheel wells and stick out a bit from the frame of the van above the tires) for my 1992 Delica Super Exceed.....it's a green and beige van.
Anyone have any suggestions as to where and how to pick some of these up?
Thanks kindly,
Lee.
Golf Cart
Vehicle: 1992 Exceed
Re: Wheel well flares wanted to BUY
Post by Golf Cart »
hi,
Do a search under "Wheel Arches". There is talk about having some made. AZor AU is the closest supply. Delicashop.com
sasquatch-hunter
Vehicle: 2 Delica
Post by sasquatch-hunter »
Hi gd,
There are two types. The wide ones are those seen on Delicas with 4" + lift with 33" X 12.5" or BFG's 325/60/15. You will need a sliding door extension as well. The narrow ones is about an inch wide. I don't think you will need the extension for the sliding door with the narrow type. Noel (Enviroimports) in Victoria is making the wide type. You should check his posts.
cheers,
sasquatch
