how-to bleed injectors?
loki
Post by loki »
Can anyone explain or point me to a go how-to for bleeding the injectors, I think that I may have a little air in the system after replacing the injectors for my WVO kit.
Adam
Re: how-to bleed injectors?
Post by Adam »
Drive hard up a steep hill. Whenever I get air in there I can purge running hard.
after oil
Post by after oil »
ive run dry, (i mean dry, because i removed the float valve in the tank that prevents you from running dry), and i just cranked until it was running again.
but i think to bleed at the injectors you open the nut that hold the pipe to the injector. if there is air there will be froth. start with injector number 1 and work your way back.
patty
Vehicle: delica chamonix
Post by patty »
does veg put a lot of wear on the injectors? (im assuming yes, but was just curious if that's true)
loki
Post by loki »
patty wrote:does veg put a lot of wear on the injectors? (im assuming yes, but was just curious if that's true)
I don't see why it would.
