how-to bleed injectors?
Posted: Sun Mar 15, 2009 7:05 pm
by loki
Can anyone explain or point me to a go how-to for bleeding the injectors, I think that I may have a little air in the system after replacing the injectors for my WVO kit.
Re: how-to bleed injectors?
Posted: Mon Mar 16, 2009 1:30 am
by Adam
Drive hard up a steep hill. Whenever I get air in there I can purge running hard.
Posted: Mon Mar 16, 2009 6:59 am
by after oil
ive run dry, (i mean dry, because i removed the float valve in the tank that prevents you from running dry), and i just cranked until it was running again.
but i think to bleed at the injectors you open the nut that hold the pipe to the injector. if there is air there will be froth. start with injector number 1 and work your way back.
Posted: Mon Mar 16, 2009 10:07 am
by patty
does veg put a lot of wear on the injectors? (im assuming yes, but was just curious if that's true)
Posted: Mon Mar 16, 2009 10:44 am
by loki
patty wrote:does veg put a lot of wear on the injectors? (im assuming yes, but was just curious if that's true)
I don't see why it would.
