Have searched (online) high and low (incl. herein), to no avail.
I'm doing the radiator, water pump/thermostat, timing and balancer belts and tensioners.
I've found herein the part numbers for the Camshaft seal and Upper Balancer shaft seal (Lordco 13907 and 9706, respectively - thanks ccautos) but not for:
- Crankshaft seal
- Lower balancer shaft seal
- Upper and Lower rad hoses
Does anyone know any part manufacturers' and/or suppliers' + their part numbers for these? ...that can be sourced at a local jobber - eg Lordco, JB Precision, Cords Key2 Auto, Napa etc.
Even if you can give me the manufacturer name + number off the old parts you may have kicking around (particularly seals) that should be enough.
...and/or if the parts (seals at least) for the 1983-1986 Dodge RAM 50 4D55 engine fit?
It's for a '92 4D56T
Thanks!
Part Numbers Aftermarket - Front engine seals and rad hoses?
- Vehicle: '92 Exceed P35W
- ccautos
- Vehicle: 92 Delica SE
Re: Part Numbers Aftermarket - Front engine seals and rad hoses?
Warning - we no longer use Lordco supplied seals as we have had several issues with the seals `spinning` with the shafts. We now only use genuine Mitsubishi seals as they are a better fit.
