Rain gaurd removal
White Mule
Vehicle: 1991 Delica L300
Rain gaurd removal
Post by White Mule »
After several search combinations, no match.
Any tips for removing the original rain gaurds without damaging?
White Mule
Blackberry
Vehicle: '92 Exceed P35W
Re: Rain gaurd removal
Post by Blackberry »
White Mule wrote:After several search combinations, no match.
Try searching for:
"guard"
or
"monsoon"
I've removed mine easily without problems. If you can wait a few weeks I should be in Alberta and could meet up with you and give you a hand.
White Mule
Thanks delicat. Its in for tinting today, I may pospone. Let me know when your in Calgary.
White Mule
robinimpey
Vehicle: 1991 Starwagon
Post by robinimpey »
There's a car wash in Strathmore that removes them for free when you get you van washed. :o
Post by Green1 »
As the general consensus appears to be that I do not know what I'm talking about, and cause more harm than good, I am removing this post so that others are not tricked in to following my ill-advised instructions.
White Mule
Quite easy to do.
1) Pull out rubber/felt window seat
2) Clips are then vissible
3) Carefully remove visor
to install, reverse.
Probably best done when warm out.
White Mule
