hard to tell exactly where. its coming from the drivers side of the motor, near the top. eegad hopefully not the head gasket. the exact spot is hidden by the alternator from the bottom and turbo hoses from the top. its just a slow drip.
anybody see this before?
coolant leak
- after oil
- after oil
Re: coolant leak
bump
40 views in 36 hours and nobody has experienced a coolant leak from this unseen place, or nobody knows what im talking about... dang
- Golf Cart
- Vehicle: 1992 Exceed
Re: coolant leak
Guess 41 needs to break silence.
Does the leak occur when the engine is running, shut off , or both ?
- after oil
Re: coolant leak
i noticed the drip after shutting off. didnt seem to see it when runningGolf Cart wrote:Guess 41 needs to break silence.
Re: coolant leak
ancient style hose clamps can be culprits
did the same thing on mine. took them out and installed ratcheting one's
- Vehicle: '91 Delica Starwagon, P35W
Re: coolant leak
got a coolant leak before. it sprayed like a spider web in size when radiator gets pressurized.
...corner tip of the sensor touches the radiator hose and pinch a small hole.
