Rear Shock Bushings.
Bessie the Mud Slayer
Vehicle: 93 Exceed.
Post by Bessie the Mud Slayer »
While on a drive yesterday one of the lower rear shock bushings dissapeared on me. After checking the wiki and a search I can't find the PN or any other info on them. I grabbed some from Lordco yesterday that appear to be a match, but would like confirmation. Also, due to a few km's with no bushing, the metal washer got pretty beat up, any info on that?
I have Energy Suspension 9.8103G for the bushing.
Duke
Vehicle: 92 Delica Super Exceed
Re: Rear Shock Bushings.
Post by Duke »
I don't know about the washer but the bushings are, lower: 9.8107G, upper: 9.8126G. I installed these on my van with Pro Comp es9000's. You can always check by disassembling the other shock bottom. :M
Chris
Vehicle: 93 Exceed.
Muchly appreciated. I was pretty dam close, but, either way, thanks. :)
Vehicle: 93 Exceed.
I did the swap today. Pretty simple process. Two things to note though. The numbers given were swapped, "lower: 9.8107G, upper: 9.8126G". The 9.8126G's are the lowers, and the 9.8107G's are the uppers, hourglass. Didn't make much difference to me because I did both sides, uppers and lowers.
Also, is it recomended to use locktite or another such product when reassembling? Not sure of the nuts coming loose during a good bounce down a backroad.
Cheers.
Duke
Post by Duke »
Loctite??? Guess we'll both find out. Sorry about the number mix up, I'm a bit cixelsyd and sometime get things back-ass wards. :? :-D
