Those darn ECU and Glow Plug questions... sorry... I had already posted an earlier ECU question at one point - but here is my final ECU question: I promise!
As my ECU - aside from properly doing its job upon cold start-up - used to keep on clicking on and off insanely - even during regular driving (sometimes I would hear the darn thing klick in after an hour drive or so... for example the North Van to Chilliwack stretch - and in Chilliwack it would still be clicking.... go figure - you'd think that by Chilliwack your engine should have reached normal operating temperature so that no further ECU / Glow-Plug action was required
As a result I burned through 3 sets of Glow-Plugs in very short succession. In order not to burn a fourth set, I had CVI check out my ECU and Butch suggested that - as a result of faulty DRL wiring by the dealer (VIB!!) my ECU actually got burnt/damaged. In order to solve the problem, he bypassed the ECU and I since have to engage the glow-plugs manually with a push-button on the dash board.
I never had burnt plugs since that. I simply push the button for about 5 seconds or so and then turn the key to "start" and it always starts. The ECU appears to be still connected to the power (but not to the glow-plugs) as it keeps clicking in - and out as you'd expect on a normal Deli during start-up.
Now here is my problem / question:
My Van spews out huge clouds of blueish / grayish / blackish smoke (the full meal deal diesel stink - but lots of it) during the initial warm-up process (first minute of running) and initially idles very rough. I tried to cope by "givin' er" another couple of short manual blasts with the glow plugs - which doesn't really seem to help in any way... Once it's warm and driving, the smoke stops... In the winter it's even worse (more smoke and longer warm-up) - I think all my neighbors hate me when they see me approach the van with the keys in my hand...
I remember on a recent post, somebody wrote that they highly recommend not bypassing the ECU - and incidentally - the warm up with the ECU connected, never resulted in a nasty smoke extravaganza... (a bit of smoke - yes... but smoke-grenade like diesel fog... no)
I would really like to have my ECU reconnected - but at the same time, I really don't want it to keep on burning one set of glow-plugs after another.
Does anybody have some suggestions?
- Is it hard to fix the ECU (I suck at soldering and stuff like that - don't wanna touch it myself)
- Is there somebody in the Delica.ca community who likes fixing ECU's?
- Is there a way to rebuild an ECU (take it to a shop or so)? If yes, who, where, at what cost?
- Are used ECU's "readily" available? Where, at what cost... any leads?
- Should I just shut up and live with my smoke generator?
Thanks for your insight... Any feedback is welcome... even snobby/nerdy one....
Chris
