Ok, so after reading way to many old posts on shocks. I need clarification.
What are the CORRECT shock part numbers?
Rancho 9000?
Munro?
kyb?
I get a wicked Lordco discount so I'd prefer to get something they carry.
RE-hash the SHOCK dilema
Re: RE-hash the SHOCK dilema
so after another day of reading shock posts I think I've narrowed the Pro Comp numbers to front 913515 and rear 919520 ?
Can anyone confirm? After looking on the Pro Comp website the 919520 doesn't list anywhere.
- Golf Cart
- Vehicle: 1992 Exceed
Meanman,
I'll check my Pro Comps later today. I do believe the last 2 numbers represents the shock travel in inches.
Procomp shocks for the L300, NOT the L400 (they are different)
Front: 313515 or 913515
Rear: 319520 or 919520
ProComp part numbering system :
319520 --- 1st number: This will either be a '9' or a '3' indicating if it is an ES9000 (gas charged) or an ES3000 (hydraulic)
319520 --- 2 to 4th numbers : Shock stroke length. 195 = 19.5" inches
319520 --- 5th number: Mounting type. 0 = eye top/eye bottom / 1 = pin top/eye bottom / 2 = eye top/pin bottom / 3 = pin top/pin bottom
319520 --- 6th number: Bushing/spacer kit that comes with each shock.
- dfnder
- Vehicle: '91 Exceed
Jesse, what would we do without you
- Golf Cart
Thanks Jesse, I knew it was something like that
Got the part number info/breakdown from the Procomp site, still curious about the other manufacturer part numbers.
