ac compressor relay location
skaguy
Vehicle: 1992 super exceed
Post by skaguy »
Hey Everyone,
I am having ac issues and the evidence is starting to point towards the compressor relay. Anybody know where it is? I have used the search function but didn't gt any useful hits.
Thanks in advance.
Rick
RaddCruisers
Re: ac compressor relay location
Post by RaddCruisers »
There are more things that can go wrong than the relays...
But they are located on the front of the heater box below the centre of the dash. There are three that I have found so far.
~john
E4 Auto Repair Ltd.
& Radd Cruisers 4WD
Duncan, BC
250 746 8977
Meanman
Post by Meanman »
behind the glove box....then refer to this post/thread
http://www.delica.ca/forum/a-c-head-scratcher-5807.html
skaguy
Post by skaguy »
We found the fuses and relays behind the glove box, all are OK. As far as I can tell from the posts I've seen they are for components other than the clutch relay. Didn't know about anything in the centre of the dash though I'll check that out next.
FYI, the system has pressure, the compressor cuts in when we energise the clutch with a patch wire from the battery and when we do this we get cold air from the ventilation.
R
Post by Green1 »
2 other things that can stop the compressor from engaging:
- low pressure cut-out switch
- full-throttle cut-out switch
If either of these switches are defective (or actively doing their jobs) the compressor will not engage (my low-pressure cut-out switch needed to be replaced)
