Hi,
I got a 94 Pajero with now 77K, i got it when it was 65K. Since it started to get cooler the front lights on the super select indicators start blinking while normal driving. When it was summer it never had that issue. What may have caused it? should i start greasing some stuff?
When i do go to 4wd it will flash solid and go back to 2wd it will disappear and it will start blinking once in a while.
I kinda want to make sure i do some preventive measures before it becomes cold out :)
Thanks !
Ryan
Super Select Lights
- kpsxtyone
- Vehicle: 94 Exceed Pajero LWB
- 39Ronin
Re: Super Select Lights
I've been there before, this really helps:
http://4wd.blogeasy.com/article.view.ru ... eID=318776]Flashing%20Light%20Fix
extremely common problem on the L400... the UK forum is full of posts asking that question.
I can't remember the details, but I seem to think you need to cycle through the whole 4wd procedure to clear it (from a stop put it in 4, drive forward a ways, put it back in 2, drive backwards a ways, and then drive forward a ways)
- Vehicle: 96 L400 lwb clr
