temp warning light went on
zyand
Vehicle: 1991 delica
Post by zyand »
just as i got home warning light came on. the temp gauge was in the middle, so im a little confused. i did change my oil on the weekend so i hope that didnt mess anything up.
thx for any suggestions.
snelson
Vehicle: 92 Delica Exceed
Re: temp warning light went on
Post by snelson »
Temperature warning light??
I don't think L300s have warning lights - my 92 L300 definitely does not have one - there's a termp gauge but no light.
Is it the "water in the filter" light perhaps? That just means you need to drain the fuel filter, or change it out altogether.
Steve
zyand
Post by zyand »
oops sorry thought it was a temp light. :? its the warning light last on the right.
snelson
Post by snelson »
Kinda shaped like an acorn? That the water in the fuel filter light.
It's not the exclamation mark in a circle though is it? That's the brake warning light - usually just means low on fluid.
Just checked - right to left is:
seatbelt
auto transmission - at least mine is - maybe yours is a 5 speed and you do have an engine temp light instead? - if this is on check your trans fluid level to start, then search this site for more info.
Fuel filter - drain the water from your filter
Brake - check brake fluid levl
