Don't want to be slipping everywhere, so get some good winter tires on if you don't already.
If you are not sure about your tires, please look for either one symbol below :
Severe snowflake symbol commonly found on snow tires and some all-terrain tires -
or for M + S (mud and snow) -
1. The peaked mountain with snowflake symbol indicates a snow tire.
2. M+S (Mud and Snow) indicates an all-season tire.
3. P stands for Passenger vehicle (or you may find L for Light-Duty Vehicle)
4. 195 is the width of the tire in millimeters.
5. 60 is the "aspect ratio" - the ratio of the height of the sidewall to the width, expressed as a percentage.
6. R Means the tire has radial construction
7. 15 represents the wheel diameter in inches.
8. 87 is the load index.
9. Q is the speed rating.
