I'm just about to start building a custom snorkel (all parts waiting in my garage,
My questions:
Should I have any concerns with the snorkel head coming up above the roof or just leveled to it (high roof) given the airflow movement above the roof? (negative air pressure?)
I could use the original air filter/canister and weld a 3" inlet but I'm very tempted to discard this unit and replace it with a shorter K&N filter with custom canister that would allow me to place a remote oil filter (by-pass filter...) underneath. Suggestions?
Going through the double walled panel... should I be fine with a drain hole at the bottom or should I seal the panel where the pipe (silicone) goes through?
I'm sure more questions will come as I get it started but thanks in advance.
David
