Hi, writing from Baja. Put van in 4L trying to get a guy out of sand and after helping I can't get it out back to 4L or 2H. I can put it in neutral, but that's it. Won't go over. A mechanic down here traced everything to the transfer case, and it looked fine. I'd appreciate any ideas for put to put to mechanics down here ... or from anyone who has had a similar problem.
-- Joel
No good deed ...
- Vehicle: 92 Delica Exceed
Re: No good deed ...
Just to be sure, you are putting the transmission in neutral before you try to move the transfer case lever? (park is not good enough, the transfer case selector will not move at all in or out of 4L if the transmission is in any gear other than neutral)
manual tranny, if it mattersGreen1 wrote:Just to be sure, you are putting the transmission in neutral before you try to move the transfer case lever? (park is not good enough, the transfer case selector will not move at all in or out of 4L if the transmission is in any gear other than neutral)
yes, won't switch even in ne
neutral
drives fine in 4L however
Check the transfer case fluid level and check the smell to see if it smells like burning gear oil.
Disconnect the shift linkage and try to shift it directly at the transfer case.
Also have someone turn the rear driveshaft by hand while shifting the 4WD with the engine off.
